1960 Whats This
Started by 60eldo, February 27, 2024, 11:24:01 AM
60eldo
Anyone no what this strange bolt is for? I found it on driver side, head bolt 2nd cyl in. Take a look, Ive never seen anything like this.
Jon. Kluczynski
marty55cdv
Looks like a guide bolt usually used in pairs to slide the head onto for correct positioning so the actual bolts can be started.
Marty Smith
  CLC #22760
41 60 Special http://bit.ly/1Wm0GvT
55 CDV http://bit.ly/1G933IY
56 Fleetwood
1958 Extended Deck http://bit.ly/1NPYhGC
1959 Fleetwood  http://bit.ly/1OFsrOE
1960 Series 62 Coupe
1960 Sedan DeVille  4 window Flattop
63 Fleetwood http://bit.ly/1iSz17J
1964 Eldorado http://bit.ly/1Wm17GA  (Living in California now)
1988 EBC http://bit.ly/1iSACKz
60eldo
That sounds right. I can see that.  Thanks I will keep it around
Jon. Kluczynski
Lexi
Quote from: marty55cdv on February 28, 2024, 12:32:24 PMLooks like a guide bolt usually used in pairs to slide the head onto for correct positioning so the actual bolts can be started.
Thats what it looks like me. Clay/Lexi
