390 crankshaft to flywheel 6 bolts. Lockwashers?
Started by paulkersey, July 12, 2014, 09:46:14 PM
paulkersey
Hello again.
This weekend I am mating my trans and engine.
I don't have any lockwashers in my dis-assembly bag but it seems the 6 crank to flywheel 75-80 ft-lbs bolts could use some.
Tried to torque them and ended up hitting the crank end with the socket and slipping off the bolt head. Some lockwashers would give
me distance out from the crank  to torque and add some lock.
Any add these?
J. Wicks # 19583
curly
I see to remember star shaped lockwashers on my 59 390, not the split type.
T Lewis
paulkersey
Thanks I was thing star washers anyway because of the thinner stamped metal it goes against.
J. Wicks # 19583
I cannot recall, but I don't think there are any washers.   But, don't forget to use Locktite on the threads.
paulkersey
It does not look like any locks go with.
So some red loctite and perhaps a crowfoot socket. I can't get a socket for torque between the crank end and bolt head.
Thanks again for helping me help myself.
J. Wicks # 19583
Not sure what brand of sockets you are using, but I had no trouble torquing up the bolts on my own '60 390.
Maybe Aussie Sidchrome Sockets are thinner than USA made ones.
Jason Edge
No washers in 63. Use loctite and torque to spec.
Jason Edge
Lifetime Member
Exec Vice President
CLC MRC Benefactor
2002 Escalade EXT - Black
But, didn't the '63 use a flex plate.
The earlier vehicles used a Drive Plate, which might be different.
