Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: Dan Eckstein on July 05, 2013, 10:47:18 PM
Title: 59 Cadillac - Trunk Photos
Post by: Dan Eckstein on July 05, 2013, 10:47:18 PM
Hello
I am restoring a 1959 Cadillac Coup DeVille that was not assembled when I bought it.  I am looking for photos to see how the trunk is normally finished.  Also are there any side panels in the trunk?  My car didn't come with any panels so I do not know.
Thanks.
Title: Re: 59 Cadillac - Trunk Photos
Post by: Grant Owen on July 05, 2013, 11:19:19 PM
Attached a couple of pictures from my 1960's both trunks are completely original, 59 are the same apart from the Cardboard lining at the bumper end.
Post by: Hayden P on July 19, 2014, 09:16:02 PM
Grant... I am about to get my trunk dipped with the rest of panels and body to get paint stripped. How do you replace this lining in the underside area of trunk lid ?
Post by: Grant Owen on July 20, 2014, 03:44:56 AM
Hayden the only way to do this is is how the factory did it , remove the Skin from the Frame & replace the Insulation. I you are acid dipping the panels make sure they are not using Sulphuric Acid as this can't be neutralised properly. Afterwards I would recommend pouring Epoxy into the seams & channels & move the panels around so the Epoxy can get into them .This will protected these areas from future rust. The pictures of mine you are looking at are original Trunk Liners & trunks  from my 60's
Post by: Quentin Hall on July 20, 2014, 04:01:39 AM
Caustic will revolve paint. Phosphoric will neutralise the caustic and remove rust. Phosphoric is the main ingredient of  most metal preps. Peeling back a trunk is a laborious task that could lead to bigger problems than it,s worth, unless you really know your way around panel work. You can carefully cut the cardboard to a fraction bigger than the correct size and try and slide it under perhaps with a plastic spatula .
Post by: Hayden P on July 20, 2014, 08:52:17 AM
It's not sulphuric acid... It's an environmentally friendly product... Not sure exactly... Sits in bath for a week or so. Maybe I will just get some tuck n roll made up to fit the spaces. It's a mild kustom after all..
Thanks for tips... I will cut insulation out before dipping.
Post by: 59-in-pieces on July 21, 2014, 03:31:11 PM
Dan,
Once again, I did not see your response that the photos Grant sent you satisfied your needs.
Therefor, I offer up some additional random photos from various cars which might help you.
Have fun,
Steve B.
Post by: 59-in-pieces on July 21, 2014, 03:39:46 PM
Dan,
Here is some more info on trunk dressing.
And if you are going to do it right, you will need the clips.
Grant
Does one of my photos look like your car - great example.
Have fun,
Steve B.
Post by: Jeff Wilk on July 21, 2014, 04:06:48 PM
Does anybody sell these clips?
Post by: Dan Eckstein on July 21, 2014, 09:35:32 PM
All,
Thanks for the photos.  Very helpful!!
