Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: trevor1978 on September 28, 2015, 10:42:31 PM
Title: Factory CB radio help
Post by: trevor1978 on September 28, 2015, 10:42:31 PM
My 78 sedan Deville still has the original am/fm, 8 track, CB radio. Does the CB part require it's own antenna? It will turn on but does not  pick anything up.
Title: Re: Factory CB radio help
Post by: TMoore - NTCLC on September 29, 2015, 11:49:46 AM
Hi Trevor -
Other folks who have one, or are more familiar will chime in, but if I recall, the factory CB radio used a single antenna for both the radio and CB, but it was different from the antenna used on cars with just the AM/FM radio - the antenna for the CB equipped cars (again, if I recall) had a "bulge" or "bulb" about 3/4 of the way up on the mast - this is the RF trap that is required for CB reception.  Start there to make sure you have the correct antenna.
Smarter radio guys here on the forum will be able to give you more accurate info than I can.
Post by: Eric DeVirgilis CLC# 8621 on September 29, 2015, 12:22:57 PM
That's correct. CB equipped cars used a power antenna that had a coil built into the mast.
Post by: bcroe on September 29, 2015, 09:44:03 PM
I have used a CB "adapter" on a standard mast, which has ports for radio and CB.  However, I
don't remember if the Cad setup will mate to this.  Bruce Roe
Post by: Coupe Deville on September 30, 2015, 12:45:24 AM
I don't know what the Cadillac am/fm/cb set up looks like. But I have a c.b in my Caddy. So maybe this is a stupid question, but is it possible that your squelch is turned all the way up? Just a thought.
-Gavin
Post by: R Schroeder on September 30, 2015, 05:49:09 PM
Also depends on how far you are from someone broadcasting.
Post by: JerRita on September 30, 2015, 08:10:12 PM
I have an 84 Brougham w/ cb My antenna was changed before I got it and my CB does not work
