In the past I have run more, but right now I am only running one fuel filter. It is located after the mechanical pump and before the carb. I'd appreciate some thoughts on running a filter before the pump, etc. My car is a 1954 CdV but obviously this question could apply to lots of years and models. Thanks, Jim
I keep my car completely stock with the glass bowl stone filter between the pump and carburetor. A filter before the pump would prevent debris (if any) from getting into the pump.
I have an online filter off the tank on the '57. I had to seal the tank because of rust and installed it when the tank went back on.
I recommend a filter BEFORE the pump because even pumps can clog.
A fuel pump pushes fuel better than it can pull it.
I have a small glass fuel filter before the pump, and reg glass after pump.
Reason is i replaced the gas tank but could not do the lines yet, and even when the line is blown, some old stuff still breaks of in the line and goes through system, and I was seeing large particles, and I was sure those would clogg the fuel pump eventually.
So since I have installed before the pump i have been catching stuff before the pump, when i see there has not been anything in small glass filter after a lot of driving i will remove.
When I had my 66 mustang, my radiator would clog, after talking to some old time mustang experts i found that a lot of the 289 engines were clay casted and later some clay left behind would work its way out and clogg the radiator holes, so someone invented,made, a filter for the radiator hose, that went between the engine and radiator, called a "Gano" filter, it worked great, amazing how much i was catching in the screen, after driving with the filter in place i would have to empty the contents and reinstall until there was nothing more getting in screen.
I am now doing that for my cadi gas lines. And i dont want to install a fix like electric pump, because i just dont want to put one on.
Also.......on the 55 there is no "sock" in the gas tank.
Jason
When I car is new to me I put a see through one between the tank and pump just to see what may be in the tank. Stock one stays in place. If it stays clear between an oil change I remove it. If it fills with crap I know I'm going to have to do something with the tank.
I should add to my comment that my method is only sort of needed when the stock filter isn't see through.
I just use one filter as stock same as back in 1970 on all my 1970 Cadillacs. The steel fuel line rust from the inside out and are steel throughout. I replaced them with the new steel lines which include some brass rust proof alloy liner so it cannot rust. Also dropped the tank and made sure it was clean and replaced sock filter at fuel pick-up tube on sender in tank. The car runs fine, no issues. Also, drive it regularly.
Previous owner added an inline filter between the tank and the hard line on my 61 and I intend to leave it as is. I still have the stock glass bowl filter under the hood, so I figure, if I don't have to disturb the glass bowl ever again, I'll be happy. Less is more with these.
With my luck, I'll either drop the glass bowl, overtighten it and crack it, or not seat the gasket properly and POOF.
Don't forget there are strainers at the carb inlet and on both needles and seats.
Quote from: Walter Youshock on August 12, 2016, 01:58:58 PM
Walter -
When did the strainers get replaced with the brass/stone filter?
Hello all,
Just an FYI, Jon's second picture is a good example of the sintered bronze filters used at the carburetor fuel inlet in many late '50s to '60s cars. Bronze powder was shaped and heated to less than the melting point of bronze (about 1750 degrees F.). The sintering process fused the bronze powder particles but left countless tiny pores which were a good filter medium. Despite the countless tiny pores, these filters can become clogged. This can be exhibited by reduced fuel flow at higher RPM. Probably to save costs, sintered bronze filters were replaced by paper filters.
My '67 has only the single stock fuel pump, but it has three "filters" - the sock-like strainer in the fuel tank, the paper filter in the glass bowl between the fuel pump and the carburetor, and the strainer at the carburetor fuel inlet.
Christopher Winter
I run a see through plastic with yellow paper filter on my 50 61 sedan, before the fuel pump.
I originally ran a glass one with a screen that you could take apart, clean and re-use, but that was letting rust through that clogged my carb. Now I just tgrow away and replace.
If you don't need the tank located pre-filter, don't use. It restricts the suction of the mechanical pump but will protect the pump diaphragm if the old girl's tank is flakey but line is good. Won't help if the line is flakey.
I'd rather put a new tank and lines in than fight a plugging prefilter every time I go up hill. If not, then clean and seal tank, put an electrical booster pump in and filter after it, and clean line to mechanical. But have to mind pressure and flow requirements of electric.
Quote from: Scot Minesinger on August 12, 2016, 08:00:02 AM
The '70 only has one?
My '72 has the one everyone knows about at the carb intake, and another
inside the pump. There's something like a 1-1/4" nut (I had to buy the socket, even with my excessive tool selection!) to get it out.
As I haven't been able able to find a sock for my sending unit, I plan on putting one of those clear ones that that set Type 1 VW engines on fire right after the fuel tank.
And speaking of such . . .
A friend grew on with trips in the '70s to mexico to visit family in his parents '60s hippiemobile. Mexican gas, at the time, was, well, . . . .
So his father put a Model T fuel filter inline before the VW filter, and would pull over every 100 miles and clean it out with a screwdriver. With that, the silly VW filter could handle what was left, and they never had a problem . . .
hawk
Hello all,
When I first resurrected my '62 Fleetwood the original fuel pump sucked debris from the tank and promptly failed. This was right before debuting the car for the first time at a Fathers Day cookout. My solution was to replace the pump, add a filter before the pump, and place a few 40# magnets on the bottom of the tank. From that point on I've never had any debris in my fuel system. I hid the additional filter below the A/C unit out of sight. I will most likely employ the use of heavy pull magnets whenever resurrecting a vehicle and the cleanliness of the tank is suspect.
Hope this tip helps ward off an untimely setback for those acquiring new to you Cadillacs.
Terry
