Cadillac & LaSalle Club Forums => Restoration Corner => Topic started by: stzomah on September 11, 2017, 12:32:03 PM
Title: RediRad AM/N install in a 56 Cadillac
Post by: stzomah on September 11, 2017, 12:32:03 PM
I did a tube radio restoration about a year ago (look up on this forum) and found that there is nothing on AM radio that I want to listen to.  I bought a RediRad AM/N unit and installed it under the dash.  I mounted it on one of the 2” ducts for the defroster with 2 zip ties.  I used a fuse tap they provided that worked nicely on the Antenna fuse.  I used heat shrink on the projecting copper and it looks very nice.  Almost looks stock!  The rest of the install was very simple.
Now that I had the converter mounted, I really needed to finish the radio restoration by installing the vintage rear speaker.  Back in 1977 (high school), I installed a Kraco Coaxial 6X9 speaker in the rear deck.  It worked great with the Pioneer Supertuner Cassette deck I had on a slide mount under the dash.  40 years later, that is long gone and I’ve gone to bone stock.  I found the original green wire that leads from the radio amplifier section (behind the front speaker in the dash), to the rear speaker.  The hardest part was re-soldering the wire to the original bayonet connector.  I needed a lot of heat out of my little soldering iron!  There is a connection on the bottom of the amplifier section (on the large transformer) that the bayonet connects to.  The speaker end, be sure to connect the negative terminal to ground.
Total success…  I was riding around listening to 21 Pilots off of my Ipad!  There’s something I did not foresee in High School!
Title: Re: RediRad AM/N install in a 56 Cadillac
Post by: 2manycars on September 17, 2017, 12:50:40 AM
That looks like a power amp section driven by two 6V6 power tubes. If that's what that is, it must sound fantastic. 10 real watts of tube audio!
Post by: J. Gomez on September 17, 2017, 08:53:52 AM
Quote from: 2manycars on September 17, 2017, 12:50:40 AM
Bill,
Remember the '56 is a 12V car the 6V6 are 6V filaments, so those are the next generation tubes 12V6GT.
Post by: 2manycars on September 17, 2017, 12:31:48 PM
Yup -- same tube, higher voltage filaments. I've heard those sets sound fantastic.
Post by: gatech1956 on August 31, 2019, 05:45:01 PM
Do you have a picture of how you hooked up the redi rad to the fuse panel?
