Cadillac & LaSalle Club Forums => Want To Buy - Cars => Topic started by: rodsragsnrides on August 24, 2018, 10:39:35 PM
Title: 49 convertible need LH frt vent window regulator.
Post by: rodsragsnrides on August 24, 2018, 10:39:35 PM
Looking to buy or trade for a 49 LH Frt vent window regulator.
I have one I can rebuild but my shaft tip  is so worn, the window handle will not properly stay on.
I have a rh hand extra that is very good shape & If I cannot find one I will have to destroy the rh extra to make one out of the 2...
Any chance some has a extra lh & needs a rh?? or just a bad left hand or rh I can cut the end off to weld onto mine... To be clear I need the piece with the drive gear that actually holds the handle on.  Have a few other parts to trade as well or will pay cash, thx Curtis Scarrow Saskatoon, Sk
Title: Re: 49 convertible need LH frt vent window regulator.
Post by: Barry M Wheeler #2189 on August 25, 2018, 08:29:30 PM
Try Bob's Buicks as a 1949 Buick Super/Roadmaster will interchange.
Post by: Brad Ipsen CLC #737 on August 25, 2018, 10:43:12 PM
I always take these apart and put new grease and mix and match parts to get good ones but is the shaft and gear different left and right.  They may not be.  The convertibles generally have a longer shaft on them so you can't interchange with a sedan but if you are willing to weld the shaft on, which I have done also you can use just about any shaft 39 and up.
Post by: rodsragsnrides on August 31, 2018, 08:28:41 PM
Thanks brad,  I will rebuild this conv one and find a 39 up shaft to weld on, probably better to find a door handle one as well....
I'm not one to ruin a perfectly good part even though it's for a modern custom....
Post by: Jeff Maltby 4194 on September 05, 2018, 10:32:12 AM
I have some nice ones off 49 sedans.
