I need ANY color of the leather insert that the door pull is attached to that is not curled up on the corners. It is about 18-19" long and about 9" high. It is directly above the arm rest and has the word "Seville" woven into it. I need it for the LH Drivers door. My restoration shop owner said that he can dye any color to match, although the light maroon would be ideal. If necessary I will purchase the entire door panel and have this piece separated from the piece that I need due to excess shipping charges.
I do not want one that is curled up on the ends as that is the problem that I have now, although I will gladly look at any part that you might have.
I also could use an original front carpet pad in dark red for either the Seville or Eldorado from the same years. Possibly one from the RH side as that one usually gets less use.
