Cadillac & LaSalle Club Forums => General Discussion => Topic started by: ithaca1230 on July 11, 2019, 12:46:43 PM
Title: leaking transmission fluid 1974 fleetwood
Post by: ithaca1230 on July 11, 2019, 12:46:43 PM
This is what mechanic sent me. Any ideas how to deal with this. Thanks
Hi Bill,
This is the transmission output driveshaft leaking inside the yoke where it slides into the transmission. There appears to be a "plug" that the fluid is leaking out of.
Title: Re: leaking transmission fluid 1974 fleetwood
Post by: Dave Shepherd on July 11, 2019, 12:54:05 PM
This is the seal to correct that. https://www.ebay.com/i/310556649408?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=310556649408&targetid=474173631829&device=c&adtype=pla&googleloc=9004949&poi=&campaignid=1669934834&adgroupid=65058350339&rlsatarget=pla-474173631829&abcId=1139296&merchantid=6567084&gclid=CjwKCAjwvJvpBRAtEiwAjLuRPfm3WZqVrGSc1mOKA5jIaUtYz1l3Y_lgaGpTLIHM8sfhT_iZRlDUYRoCD2wQAvD_BwE
Post by: ithaca1230 on July 11, 2019, 03:07:06 PM
is this a relatively easy fix? thanks
Post by: MikeLawson on July 11, 2019, 04:50:47 PM
Here is another seal kit which includes the O-ring, output shaft seal and transmission tail shaft housing gasket.  I bought this kit to fix my transmission leak but I have not yet installed it. The tail shaft housing must be removed in order to make the repair but I don't think it will be too bad a job.
Seal Kit: https://www.ebay.com/itm/Rear-Tail-Extension-Housing-Reseal-Kit-Fits-GM-TH400-THM400-3L80-Transmissions/111495961324?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Post by: bcroe on July 11, 2019, 06:19:34 PM
A couple output shaft seal arrangements were used.  One used an outer yoke sleeve
that extended over the output shaft past the splines.  It slid on that big O ring on the
shaft, as an oil seal.  To let air out there was a small hole in the center of the yoke.
The hole leaks oil if the O ring fails, or if an output shaft with no O ring is used.
That O ring is in every TH400 rebuild kit.  If it fails, it is a hint at what condition rest
of trans rubber is in, some in far more critical functions.  The trans should be apart
every couple decades for a rubber refresh, independent of miles, mine are.
Bruce Roe
