Looking for a pair of solenoids for the '56 six way power seat. I have one that works but the other two dont. Anyone have a pair I can buy for a reasonable price?
Thanks!
I assume the ones the shaft runs thruogh. I have them.
First, does it sound like they are trying to work? If so, I have found they are just gummed up and can be freed up by carefully removing the aluminum cap off the top. Be careful, there is a very TINY spring under the plunger. Spraying Knockp[r[loose and working them typically frees them up.
Might save you some money.
Yes they are the ones that the shaft runs through. I got the tops off freed everything up BUT when 12V is applied to them they dont energize. Only one of thee does
