I need this 1968 Fleetwood exhaust bracket
wraps the exhaust pipe and then 90 degrees into the hanger.
Still looking for this bracket....
Hard to find Mike. I made mine for my '66 with a piece of steel from Tractor supply, and a torch, and a pvc pipe :) Chuck
Chuck do you have a picture of that somewhere?....PVC pipe?
Quote from: Mike Baillargeon #15848 on May 23, 2020, 10:53:56 PM
Oh, to clarify, whatever size is your pipe/resonator, buy or just get a piece of pvc the same size. put the pvc in a vice and bend the metal around the pipe as a template. Anything with the same diameter can be used to bend the metal into a circle.
Ok got ya...
Thanks Chuck
