Hi I need this washer is for the front suspension between Coil Spring and frame
has 5 3/8" Outside by 4" inside
If the 60 models are built similar to the 56's, you only need one of those, it goes on top of the right front spring to compensate for the weight of the air conditioning.
Rick
OMG thanks a lot, yes my has only one in the right side.
Thanks a lot
Quote from: MIKIMBIN1 on July 20, 2023, 07:02:57 PMOMG thanks a lot, yes my has only one in the right side.
Thanks a lot
No problem, glad to help. It took me a while to figure out why I only had one of those too.
