Can anyone recommend a brake shoe that fits a 1967 Sedan Deville. I tried Raybestos but one of the holes is off
Has anyone changed the brake pads on a 65 - 67 Cadillac? If so what brake shoes did you use?
Thank You
Ken
Interestingly, Rockauto has the same listing of shoes for 1957 as they do for 1967 but the crossover book states 53-59 are interchangeable and 60-65 are interchangeable seperately. The book does not say what the differences are nor does it go up to 1967. However, since you're using a 127, perhaps try the 419s instead and see what happens? I recall having some sort of issue when installing the same 127 shoes you had on my 57, I just put them on the other side of the car and things lined up better but I cannot recall with 100% certainty what the issue was.
