Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: Cadillac Jack 82 on November 02, 2023, 11:55:38 AM
Title: 1959 Jetaway Rebuilder in Phoenix, AZ?
Post by: Cadillac Jack 82 on November 02, 2023, 11:55:38 AM
Good morning,
While my transmission is doing alright for now I've noticed its leaking semi-steadily and it tends to not want to shift easily from 3rd into 4th gear.  While its okay now I think after 65 years and nearly 95k miles it might be time to have her rebuilt.  Does anyone here have a shop they'd recommend for a rebuild here in the east valley of Phoenix?  Also with regards to rebuild kits does anyone here recommend a vendor?  Thank you.
Title: Re: 1959 Jetaway Rebuilder in Phoenix, AZ?
Post by: V63 on November 02, 2023, 02:05:38 PM
Verify your fluid is still red? I have had great sucess with Lucas transmission elixir. Also your transmission might need a linkage adjustment?
Past all that, I have used DENNYS transmission for decades, they reduced to one valley location but it's near suncity on grand Ave. Ask for Sean
 I might coordinate a schedule on such a project as those old transmission jobs are not 'typically' prioritized.
Post by: Cadillac Jack 82 on November 02, 2023, 03:04:06 PM
Transmission fluid is still bright red and I top it off with Dextron/Mercon fluid from NAPA.  The transmission not grabbing is more prevalent during a hard acceleration moreso than cruising so I stick to that.  Although Sun City is all the way on the other side of town I'll look into Dennys and also your Lucas recommendation.  Thanks!
Post by: Chris McBride on November 02, 2023, 05:54:16 PM
You may wish to check with Mr. Dave Riccio at Tri-City Transmission in Tempe.
https://tricitytransmission.com/
2005 E Rio Salado Pkwy, Tempe, AZ 85281
480-968-5062
Hope this helps.  Good luck!
Chris
Post by: V63 on November 02, 2023, 06:39:02 PM
Quote from: Cadillac Jack 82 on November 02, 2023, 03:04:06 PMTransmission fluid is still bright red and I top it off with Dextron/Mercon fluid from NAPA.  The transmission not grabbing is more prevalent during a hard acceleration moreso than cruising so I stick to that.  Although Sun City is all the way on the other side of town I'll look into Dennys and also your Lucas recommendation.  Thanks!
Just a suggestion,
The red fluid is a very good indicator.
Under heavy acceleration there is accelerator linkage to facilitate a down shift (TV ROD) and if that's not adjusted correct the transmission will hunt (slip) between #3 and #4 speeds.
As a quick guide to adjust,
car off!
floor the accelerator and set the downshift lever/ linkage on the transmission to a fully pulled situation. Fix it there.
Sometimes with replacement carpets and padding the accelerator travel can be restricted.
