Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: Cadillac Nut on November 21, 2023, 11:29:36 AM
Title: 1969 Door Strikers
Post by: Cadillac Nut on November 21, 2023, 11:29:36 AM
None of the 4 doors shut like they should on my '69 they are a little 'loose' when closed or have to be slammed, do the door strikers wear out on these cars?  Just wanted to get some opinions before I start changing strikers or taking latches apart.
Title: Re: 1969 Door Strikers
Post by: "Cadillac Kid" Greg Surfas 15364 on November 21, 2023, 12:35:04 PM
Are the "insulators" still intact?
Greg Surfas and
Post by: Clewisiii on November 21, 2023, 01:51:04 PM
Often it is the hinges saging causing the latch and striker to be out of alignment.
Post by: The Tassie Devil(le) on November 21, 2023, 05:23:37 PM
Have a serious look at the locks themselves as well as the hinges.   They do wear out.
Before and after shots of the lock reconditioning.
Post by: Cadillac Nut on November 22, 2023, 01:31:19 PM
One has a hinge sag issue but the others do not.  I replaced the front door latches with good used ones I lubricated and tested the replacements they seemed to be fine, rears I've never touched.  Insulators, you mean the part that spins on the striker shaft?
Post by: "Cadillac Kid" Greg Surfas 15364 on November 22, 2023, 02:26:36 PM
Yes,
the cylinder (plastic) that goes over the shaft
Post by: Cadillac Nut on November 24, 2023, 11:22:35 AM
If there's supposed to be a piece of plastic on that shaft it's missing from all of mine
