Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: Turboba6 on November 26, 2023, 05:34:34 PM
Title: 1980 Eldorado 350 Gas Injector orings
Post by: Turboba6 on November 26, 2023, 05:34:34 PM
Folks,
Where do these Copper rings go, my Original injectors had only the 3 Top Hat for the Rail and the Rail oring and the Fat injector oring...Thanks!
Title: Re: 1980 Eldorado 350 Gas Injector orings
Post by: TJ Hopland on November 26, 2023, 08:17:00 PM
Do the other bits seem to fit?   If not I wonder if you ended up getting a set for a diesel?  Those did use copper washers.  80 had 2 different styles and what you have isn't the style I know but it could be the earlier version, I know those had a few more connection points than the ones I new.
Post by: Turboba6 on November 26, 2023, 09:09:35 PM
Hmm, I got the Part number shown in the pic, from this board, and it's Listed as 350 Gas...maybe Bruce will chime in...Thanks
Post by: jagbuxx #12944 on November 26, 2023, 09:46:25 PM
Crush washers go where the metal lines fit with each other and at pressure regulator.
