Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: jgalin on November 28, 2023, 03:44:26 PM
Title: '85 Eldorado Bumper Fillers
Post by: jgalin on November 28, 2023, 03:44:26 PM
I have a 1985 Eldorado that requires new front and rear bumper fillers.  Suggestions from members on the correct material, general advice, and leads of installers in the Chicago area would be greatly appreciated.  Thanks!
Title: Re: '85 Eldorado Bumper Fillers
Post by: smokuspollutus on November 28, 2023, 10:10:41 PM
Buy a set of the flexible replacements for the front corners. They fit the best overall. Leave the ones under the headlights alone.
For the rear ABS is your best bet. The rears are easier to do than most other models.
Post by: James Landi on November 29, 2023, 07:34:53 AM
I've personally installed aftermarket fiberglass knock-offs--- attempting to fit the original brackets was not possible; as stated above, you'll need flexible ones.  I was able to attach the cheap fiberglass ones, and did a reason job rattle canning an approximate paint match.  You can spend a lot of money doing this ''right,'' or you can do what I've done on several occasions, that suit my purposes just fine.
Post by: jgalin on November 29, 2023, 10:09:33 AM
@smokuspollutus, @James Landi
Thank you both for your input.  For the front corners are you therefore suggesting fiberglass?  Do I leave the ones under the headlights alone because they are difficult to replace?  Thanks.  Jim
Post by: smokuspollutus on November 29, 2023, 10:39:26 AM
No, no fiberglass. Those are the worst option. There is a vendor making flexible replacements for the front corners that are similar to the originals. They cost a bit more but are worth it as ABS/fiberglass are almost impossible to fit there.
The ones under the headlights are made out of a different material that don't seem to disintegrate. I would leave them alone as the new ones available for that spot are again either ABS or fiberglass and don't fit right.
The rears are only available in ABS or fiberglass but the ABS is a lot more forgiving to work with. Overall the rears are easy since there aren't really any body lines that have to line up perfectly with the fillers. Not the case with the front corner pieces which flow into the fender extensions.
Post by: jgalin on November 29, 2023, 04:45:25 PM
I really appreciate the feedback.  Do you happen to know the name of the vendor that makes the flexible front ones?  The ones under my headlights are actually in fine shape so I don't want to mess with them.  I am pretty sure, though, that I will have to remove the front bumper to get at the corner fillers.
For the rear I will go with ABS.  Any suggestions on sources?  Thanks much.
