Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: 7gen on March 11, 2024, 07:40:16 PM
Title: 1976 Eldorado headlight improvement
Post by: 7gen on March 11, 2024, 07:40:16 PM
I don't like driving my 1976 stock Eldorado at night. Those headlight just don't seem very useful. I've done some searching on this site and halogens seem to be an option. LEDs don't seem to be worth the hassle. I'm looking for something relatively easy to fit my relatively modest skills. If I go the halogen route, is there a recommended product? Do I lose the fiber optic indicators? And is there some writeup where someone has done this so that I don't end up frying my electricals? Is halogen my best bet or is there something that can be done to improve the stock system? Thanks!!
Title: Re: 1976 Eldorado headlight improvement
Post by: The Tassie Devil(le) on March 11, 2024, 08:19:00 PM
G'day Kevin,
I am the person that adapted his Fibre Optics to work with the replacement globes.
The secret is to aim the end slightly towards the illuminating part of the globe to get the best results.
The high beam only can be positioned a bit different, whereas the Low Beam needs access to that filament.  Notice on the back side, the brass ferrule has been filed flat on one side to assist in locating.
Replacing the lights was a no-brainer, as with the E-Z-Eye tint on the windscreen, one needs all the illumination that one can get.  Next time you are out in the dark of night, you can see just how much light is lost by the tinting if you turn the lights on, then open the window and look out past the windscreen post.  Yes, I was shocked.
Post by: 7gen on March 11, 2024, 10:26:39 PM
Thank you!!
Post by: Cadman-iac on March 12, 2024, 12:09:21 AM
You can also use the halogen replacements for the sealed beam bulbs,they are physically identical to the original sealed beams, but have a halogen bulb inside. The nice thing about these is if you should catch a rock and the lens cracks it doesn't burn out like a typical sealed beam bulb would.
They're just a little more price wise than the sealed beam, but they give off a much better light and brightness. I've been using them for all my vehicles for years now. They have ones that replace the old round 2 light system, the larger rectangular 2 light system, and the rectangular 4 light system.
I think for your Eldorado they are a Sylvania H4651 for the high beam, and a Sylvania H4656 for the low beam, if you have the 4 rectangular bulbs. Those are the same as my 88 Suburban and what was on my old 75 Coupe Deville.
Easy to change, plugs in exactly the same, and they have the little glass tit on the back for the fiber optic to work with.
Rick
Post by: TJ Hopland on March 12, 2024, 01:00:00 AM
Maybe poke around some other GM forums to see what they are doing?  F body? Trucks? You would think by now someone would have come up with a decent LED.
Unless something has changed the last 20 or so years of production for the original style sealed beam lights were crap.  Story I heard was the die or molds or what ever it was that Sylvania or GE or who ever it was used to make them had worn to the point where they knew the quality was not what it should be and they didn't feel that there was enough of a market left to invest in new tooling so they sold the worn out machines to someone else who just patched them up with chewing gum and duct tape and went back into production.  Result is the shape isn't quite optimum for reflecting the light where you wanted it and they just kept getting worse.
The issue with the monitors is the original bulbs had the sealing nipple on the back from the glass manufacturing process.  This was where the fiber optic was pointed and that nipple area didn't get any of the reflective coating so light from the bulbs would basically shine out that hole.  Later production bulbs they changed the process and used a fairly opaque plastic plug so you just don't get the amount of light through it that you did on the originals.
Post by: winger888 on March 12, 2024, 04:02:44 AM
In Europe the sealed beams are not allowed so all American cars get new lamps from Hella or Bosch. To change them is not a big deal and they come with a regular H4 halogen bulb. Better than sealed beam but still not good.
A while ago Osram and Phillips came out with LED bulbs with a H4 socket and exactly the same bulb size like the regular H4 bulbs. So it is a simple plug and play game.
These LEDs have 230% (!!!) more light than the regular H4; last forever and use less current.
I have them in my 76 Eldorado and my 79 Lincoln. Hi Beam is now like the fireworks.
It is worth the "Hassle" !
Post by: smokuspollutus on March 12, 2024, 10:27:52 AM
You can still get new old halogen sealed beams for cheap for a big improvement in performance. There are other ways of getting more volts to the bulbs that would marginally improve performance, or newer Hellas or LEDs but the least invasive that still lets you keep your lamp monitors are the halogens, preferably the older kind with the nipple on the back or plastic lens to direct the light into the fiber optic.
Post by: TJ Hopland on March 13, 2024, 01:20:38 AM
Quote from: winger888 on March 12, 2024, 04:02:44 AMIn Europe the sealed beams are not allowed so all American cars get new lamps from Hella or Bosch. To change them is not a big deal and they come with a regular H4 halogen bulb. Better than sealed beam but still not good.
Is there an easy way to get the European setup in the USA and if we were to get them will they stand out and annoy other drivers?  I know thats a strange concern to have when so many owners buy amazon and ebay crap that isn't even remotely legal and just to make sure they blind oncoming drivers do the same with their fog lights which they always have on.
Quote from: smokuspollutus on March 12, 2024, 10:27:52 AMYou can still get new old halogen sealed beams for cheap for a big improvement in performance. There are other ways of getting more volts to the bulbs that would marginally improve performance, or newer Hellas or LEDs but the least invasive that still lets you keep your lamp monitors are the halogens, preferably the older kind with the nipple on the back or plastic lens to direct the light into the fiber optic.
Have you bought these recently?  And you found their performance decent?  Its probably been 5+ years since I tried and back then I ended up keeping the original non halogens that were either on the car when I got it or in my junk pile because they had a much more useful beam.  The 'new' ones were brighter but it wasn't directed anywhere useful.  Also how do you know if you are getting ones with the nipple or plastic?  Or are you getting them from a store where the packaging lets you see that?
Post by: The Tassie Devil(le) on March 13, 2024, 01:49:10 AM
I have always wondered about LED globes for headlights, where the units are designed for reflecting the light that the LED's put out.
The Headlights, unlike other car globes, have a reflector specifically built to put the illumination in one plane when on Dip, and a different projection when on full.
I cannot imagine that any aftermarket supplier would spend vast amounts of money tooling up for lights for cars that haven't used that style of headlight for 40 years.
When I converted a 1975 Mercedes Benz to RHD, all I had to change was the head light globe to get the dipping illumination span correct.   I envisaged having to buy an Export Reflectors and Lenses, but found it was just the new globe.
Post by: TJ Hopland on March 13, 2024, 02:02:18 AM
In the US we had the sealed beams from at least the late 40's till into the 90's when some models started using what we called the composite headlamps which are the ones where they tended to be contoured to the body and those use the raw bulbs/globes.
I think I saw a youtube video explaining that headlights were standardized in the USA and originally there was only one option so if you were selling a car to be used on the roads in the USA you had no choice you had to make those lights fit and work.  In later years there were a few options but I think it was only maybe 3 or 4 different styles which included imported cars, they had to hack in the USA approved sealed beams.
Post by: Seville Life on March 13, 2024, 07:22:00 AM
I don't believe sealed beam units are illegal in Europe, lived in France for years and the CT test allowed them?
I do though have Cibie Euro units in mine with hi/lo bulbs. The inners, main beam only are American halogen and great. However our original wiring (I was told) wasn't heavy enough for hours of halogen use?
The other option is to buy one of those relay kits that allow all your headlamps to run directly off the battery, I think the figure is around 20% better light? There's a guy in the Club that sells the kits.
Post by: TJ Hopland on March 13, 2024, 10:53:56 AM
I remember hearing about the wiring issues and in the context of the 70s/80s rectangle quad beam setup there was no significant difference in the current draw between the standard and halogen styles.
I'm assuming that that rumor started for a reason so there must have been a style where that was not the case and the halogens drew more power. Maybe the pre quad beams?
Post by: Roger Zimmermann on March 13, 2024, 01:20:31 PM
I too believe that there is not much more current involved by running halogen bulbs/halogen sealed beam. It's a simple calculation by looking at the power (watt) divided by 12 (volts). I don't have bults at home; I thing halogen H4 have 45/55 watts (low/high beam).
Post by: 7gen on March 13, 2024, 08:37:21 PM
Quote from: Cadman-iac on March 12, 2024, 12:09:21 AMYou can also use the halogen replacements for the sealed beam bulbs,they are physically identical to the original sealed beams, but have a halogen bulb inside. The nice thing about these is if you should catch a rock and the lens cracks it doesn't burn out like a typical sealed beam bulb would.
Rick
Taking your advice, I looked it up on the Sylvania sight and the model numbers are correct! Very good tip. Thank you so much!!!
Post by: Cadman-iac on March 13, 2024, 09:06:23 PM
Quote from: 7gen on March 13, 2024, 08:37:21 PMTaking your advice, I looked it up on the Sylvania sight and the model numbers are correct! Very good tip. Thank you so much!!!
  I've never had an issue with the wiring using the halogen sealed beam replacement bulbs. The wattage for these is the same as the incandescent sealed beam bulbs, which is 55 watt for the high beam, and I think it's 45 watt on the low beam just as Roger mentioned. The wattage is limited to those specs by the government. Even the conversion systems I believe are limited to the same maximum wattage.
I've used them on 4 different mid 60's trucks,my 81 El Camino and Malibu, and my 88 Suburban, all with just the stock wiring. And if I ever get my 64 Olds Starfire going, I'll put some in it too.
If you ever do experience a wiring issue, it's really easy to add a pair of relays to run power from your battery and use the stock wires to control the relays.
But like I just said, I haven't found that necessary.
  Good luck with your project.
Rick
Post by: winger888 on March 14, 2024, 05:45:12 AM
Dont know about all of Europe but in Germany no sealed beams in antique cars are allowed. The H4 and H7 bulbs draw more current than the sealed beams and it is very common to work with relays. No relays may result in flickering lights after a couple of minutes or a fire near the light-switch (especially Lincolns)
The H4 and H7 from Osram cost about 100€ a pair. No chunk! They are build like a halogen H4/H7 so the light distribution is no problem.
Post by: smokuspollutus on March 14, 2024, 09:26:02 AM
Quote from: TJ Hopland on March 13, 2024, 01:20:38 AMHave you bought these recently?  And you found their performance decent?  Its probably been 5+ years since I tried and back then I ended up keeping the original non halogens that were either on the car when I got it or in my junk pile because they had a much more useful beam.  The 'new' ones were brighter but it wasn't directed anywhere useful.  Also how do you know if you are getting ones with the nipple or plastic?  Or are you getting them from a store where the packaging lets you see that?
TJ, I should clarify that these are new old Delcos, sylvanias, GE's etc from eBay. Not new from a parts store. So the brightness is better than the regular sealed beams and still has a good spread. So far they have all had the nipple or plastic lens. I saved a few of the plastic lens for the day the supply dries up or at least gets out of my price range. I drive my '83 daily for 9-10 months of the year and do a lot of night driving so I do go through bulbs. With the halogens the lighting is more than decent. And the so-important lamp monitors jive with it.
I haven't had any heat issues in my age range (70s-80s) but it should be noted that these cars came stock with halogen high beams around 1979(?) or maybe 1980, and a switch to halogen low beams came during the 1984 model year. No changes in switches or wire gauge during that time period.
Post by: Cadman-iac on March 14, 2024, 09:53:01 AM
  I admit that I haven't had to buy a replacement halogen headlight for years now, so I'm not aware of any issues with the new ones. I don't do a ton of night driving like I used to anymore, and I've also had a stash of bulbs from parts vehicles to pull from when needed.
 I'll have to go look at what is available on the shelf in my local stores.
 I don't even remember what I put in the 56 headlight assemblies when I restored them. I guess I should check those too now.
 Thanks for the heads-up on the quality of new bulbs.
 Rick
Post by: Seville Life on March 14, 2024, 12:04:06 PM
Thank you for that guys. I always worried when doing long night drives running the halogen for hours? I always though the wiring wouldn't take it. Appreciated.
The firm I was thinking about that does the relay kits is...
https://www.danielsternlighting.com/
...interesting firm.
Didn't know that about Germany. Thanks all.
Post by: TJ Hopland on March 14, 2024, 01:01:43 PM
My guess is there was a popular earlier car that started the rumor that there were issues.  Something that maybe had slightly undersized wire to start with and maybe the original bulbs were lower wattage than the 3rd party halogens when they came out.
My guess is the 70's stuff there were enough cars on the road and it was still the current style when the halogens came out so some actual thought and engineering went into them. But a 60's or older car?  Seems more likely that a 3rd party just said hey why don't we shove the 80's bulb into the 60's housing. If it was a popular car like say a tri5 chev or mustang that survived in large numbers that actually had a problem you could see why 'they' say its a problem even though for most cars its apparently not.
Post by: Finndorado on April 17, 2024, 11:51:47 AM
Hi Peter !
Where did you get your lamps ? -76 Eldorado has square ones but my -73 has round ones (normal selaed beams).
So you don`t have to do anything else than change the lamp and then put an Osram led bulb, correct ?
I would like to give it a try.
Mika
Post by: winger888 on April 18, 2024, 02:10:41 AM
Hi Mika,
that is correct. My Eldorado has square and the Lincoln has round lamps. Just make sure you have the H4 bulb lamps and sockets.
I got my bulbs from Sebastian but I guess you can easy order them online.
Regards Peter
Post by: Finndorado on April 18, 2024, 03:30:10 AM
Quote from: winger888 on April 18, 2024, 02:10:41 AMHi Mika,
Regards Peter
Thanks Peter, but I meant the lamps, to replace the sealed beam.
Where did you find your own ones ?
Mika
Post by: Big Fins on April 19, 2024, 11:59:27 AM
If you plan on using halogens, put relays in the area of the headlights themselves. Halogens use some serious power and the relays will pick up the load off of the headlight switch and the dimmer switch.
LED's are great, but look ugly as sin. They also cause a white out when driving in fog. Incandescent bulbs are the best for foggy driving. I have the regular halogen sealed beams in mine. Aimed properly, there are no issues with night driving.
For maintaining usage of the fiber optic monitors, if the little rubber sections are missing in the headlight plugs, cut a 3/8" section of 5/16" vacuum line and as you are plugging the pigtail into the rear of the bulb, slip the section of vacuum line right into the center of the plug and press it home. While you have the plugs off of the bulbs, take a toothbrush and clean up the ends of the fiber optics. It makes the hood and rear deck monitors so much brighter.
Post by: TJ Hopland on April 19, 2024, 12:58:12 PM
Quote from: Big Fins on April 19, 2024, 11:59:27 AMIf you plan on using halogens, put relays in the area of the headlights themselves. Halogens use some serious power and the relays will pick up the load off of the headlight switch and the dimmer switch
What year and model did you experience this 'serious power' draw when compared to the OE bulbs on?   I keep seeing that statement and assume its true but I don't think anyone has ever came up with details.  In the 70's GM cars at least the bulbs I have personally measured there was no significant difference in the draw between the types.
Yes it will reduce the draw if you install a relay but does it really gain you anything vs adding extra parts?  I would argue in 70's GMs no gains.  I'm open to hear about other years where it is an issue?   Maybe in the context of outside the USA where they are fitting bulbs no originally designed for USA cars I could see the draw being different.
Post by: TJ Hopland on April 19, 2024, 01:05:48 PM
Quote from: Big Fins on April 19, 2024, 11:59:27 AMFor maintaining usage of the fiber optic monitors, if the little rubber sections are missing in the headlight plugs, cut a 3/8" section of 5/16" vacuum line and as you are plugging the pigtail into the rear of the bulb, slip the section of vacuum line right into the center of the plug and press it home. While you have the plugs off of the bulbs, take a toothbrush and clean up the ends of the fiber optics. It makes the hood and rear deck monitors so much brighter.
This only works if you have a fairly old production bulb that still has that nipple on the back, or have you found a reliable source for bulbs that still have the glass nipple?  Last time I was working on a possibly 80 Cadillac I tried some different brands and kept getting identical bulbs in different boxes that had an white opaque plastic plug instead of the clear glass nipple and they just didn't let much light out.  For sure you had to get it as clean as possible to have a chance.
I will have to look but I think the last square bulbs I bought that plastic plug was black so no light at all gets out, glad those were not for a Cadillac that had monitors.
It may be getting to the point where someone will have to come up with a likely LED light that will shine in the optic so at least it will work.  Won't tell you that your real bulbs are working but at least you will still have an idea what you have or have not selected to be on or off.
Post by: Big Fins on April 19, 2024, 01:41:09 PM
I remember the switch on my '59. It would get hot as hell with the halogen bulbs but remain just warm to the touch with the incandescent lights. That thought always carried over to other cars that I would change the bulbs out in. I have no solid numbers as far as amperage draw. But I can really feel the difference in the switch temperatures.
Could it be weak connections? Maybe, not all that sure. I clean them up with contact cleaner and then put them together with dielectric grease. That really helps keep them clean. It sure made a difference in the windshield wipers in my recent '69. They would never park. One of the member did a write up in the S/S about it, I tried it and they worked just like new.
The older sealed beams did have that glass 'tit' that really helped the monitors. The newer ones are mostly just flat. That's why I use the vacuum line. It channels the light to the fiber optic cord. It's not nearly as bright as the older bulbs, but it still works. At night you can see them okay, but during the daytime, it's pretty much useless.
Post by: TJ Hopland on April 19, 2024, 02:00:18 PM
Originally at least on the 70's and 80's cars it seemed like it was a foam rubber sort of material that made up that sleeve so if it was even there the first time you had to change a bulb the next time it likely just was too brittle to re use.   I too used hose. I think I was several Cadillacs in before I got one that still had the sleeve in there so I didn't even know it was a thing for ever.  I would guess it was mostly there to try and keep that area clean.
Post by: winger888 on April 30, 2024, 01:37:49 AM
Quote from: Finndorado on April 18, 2024, 03:30:10 AMThanks Peter, but I meant the lamps, to replace the sealed beam.
Hi Mika, just look for Bosch or Hella. Sorry for responding so late. Had the Eldorado out for a wonderful trip to Tuscany/Italy
To make it clear again because of other comments: replacing sealed beams lamps by halogen lamps does draw more amps and may result in malfunctioning including fires.
We are talking LED bulbs not lamps. The appearance is like the original build.
Post by: Finndorado on May 02, 2024, 04:40:51 AM
Quote from: winger888 on April 30, 2024, 01:37:49 AMHi Mika, just look for Bosch or Hella. Sorry for responding so late. Had the Eldorado out for a wonderful trip to Tuscany/Italy
Ok, thanks Peter :)
Mika
Post by: amarzano on June 16, 2024, 12:40:58 AM
has anyone had experience with these from Holley? They LOOK like the stock lights, but are LED.
Wondering if they can be adapted to work with the lamp monitors.
https://www.holley.com/products/electrical/led_lighting/retrobright/parts/LFRB120-1
Post by: TJ Hopland on June 16, 2024, 01:06:32 AM
Looks interesting.  If anything has a decent chance of not being awful it could be these.  For the money they better work.
On the monitor front there is that odd nipple like thing on the housing that could be some sort of port into the reflector area.  If they were like $30 each I would risk messing with that to see if it could work but at $200 a pop I would be afraid that messing with that would compromise things and shorten their lives.
Post by: TJ Hopland on June 16, 2024, 01:08:38 AM
I forgot to finish my thought on the monitors,  I think if it was me I would rig up a smaller LED and wire it into the connector and use heat shrink to connect to the fiber.
Post by: The Tassie Devil(le) on June 16, 2024, 03:27:18 AM
If there is any light source that the Fibre Optic could be aimed at, then it would work, but you would have to drill into the housing to get that source.
A bit useless if you put a globe into the end of the Fibre Optic line, and then the head light blows.   The Fibre Optic stays on, and the driver doesn't get the signal that the headlight has blown.
Plus, with Headlights, there are two Fibre Optics.   One that shows the Low Beam, and the other, the High Beam.  The third Optic is for the Park Light/Indicator Light.
Post by: Big Fins on June 16, 2024, 04:24:08 AM
I think that at $200 a piece, they are going to be sitting on their shelves for a looooooong time.
Post by: bcroe on June 16, 2024, 10:22:53 AM
I have had a lot of quad rectangular headlight
cars, all equipped with halogen bulbs.  One I
ordered that way from the factory, none used
relays to power them.  Same wattage means same
wiring load.
However old cars can have wiring issues.  If
there is enough resistance in the wiring to
generate heat, probably that will cause contact
oxidation, more resistance, more heat, till it
outright burns out.  Relays can help avoid this
happening, and feed peak voltage the lights need
for peak brightness. Bruce Roe
Post by: amarzano on June 17, 2024, 12:38:19 PM
Quote from: TJ Hopland on June 16, 2024, 01:06:32 AMLooks interesting.  If anything has a decent chance of not being awful it could be these.  For the money they better work.
TJ
I believe that is a vent port on top. I have these ports on other LEDs for some motorcycles. They help vent air and moisture. I was thinking the same thing to have the fiber run in there.
No doubt these are pricey, but now that they are out there, the trend is for the cost to come down.
I run LEDs on various other vechicles and have found them to be the leading tech in lighting right now, when considering output, power consumption and heat.
I have replaced all the courtesy lights in my car with LEDs for fear of the plastic lens melting. Still keeping with the warmer colors.
Alex
Post by: amarzano on June 17, 2024, 09:06:59 PM
Quote from: amarzano on June 17, 2024, 12:38:19 PMTJ
Alex
And here we go - much cheaper version $135 for 4 lamps,  that looks like it might work with the lamp monitor mod above.
(https://i.ebayimg.com/images/g/6OsAAOSwWSZmKhbT/s-l1600.jpg)
https://www.ebay.com/itm/135033328915?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=w35pgbuvqe-&sssrc=2047675&ssuid=MYdS7fq8RIm&widget_ver=artemis&media=COPY
Post by: TJ Hopland on June 17, 2024, 10:26:45 PM
I dunno, the Holley ones are expensive but I think they have a very good chance of being good performers.  That ebay ad has all the hallmarks of being just another sort of cloned junk product.   If someone has tried them or wants to be sure to let us know how they work out and that includes having someone else drive your car after you install them behind you and coming at you while you are driving a car not some tall truck or suv.
LED's by nature are super directional so it takes a lot of extra work to get them to do what was much easier to do with an incandescent lamp.  I didn't dig into the Holley one but I didn't notice if it had a replaceable 'lamp'.   The Ebay housings look like they were made to fit some sort of universal replacements.   I'm not saying that can't work and that that isn't what Holley did.
Also look at the certifications for the ebay one,  OE certified?  Seems like they are just throwing in keywords. "No blind oncoming drivers"... ya right and 6500K?  5000 is institutional white and 5600 is about the limit before you start really looking blue so 6500 is gonna be pretty blue.     Originals would have been maybe 2700 and halogens maybe 3000.
Post by: Big Fins on June 18, 2024, 04:08:18 AM
In foggy or snowy conditions, LED's are useless. They create a white out in which there is no beam to pierce the fog or snow. Incandescent lights are the way to go when you really need to see. LED's just scream, 'Hey, look at me, I can blind everyone'.
Post by: bcroe on June 20, 2024, 04:34:20 PM
When I started driving, very high miles at night,
I found the most important things..
1. Keep the headlights absolutely clean.  That means
clean them every time you stop, gas or other reason.
2. Make sure they are accurately aligned.  I did
this on a straight, dead end street by throwing a
coat over any light not being adjusted.
I found 4 headlight systems a necessity, so the
low beams could be set low enough not bother
anybody, while my powerful high beams were
optimized for distance.  I even changed to a later
front clip on a car to achieve this.  good luck,
Bruce Roe
