Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: dbzsjones on February 08, 2025, 03:49:22 PM
Title: 1961 Hydromatic help
Post by: dbzsjones on February 08, 2025, 03:49:22 PM
I've got a couple questions I'm hoping someone can help me with.  The question I should have asked before now.  Is there a torque spec for the nuts that hold the flex plate to the fluid coupling.  Next question, any advice on how to deal with a broken off stud?  I'm going to drag it to the local transmission shop Monday, but would like to be educated on what I might be getting into.
Title: Re: 1961 Hydromatic help
Post by: Big Fins on February 08, 2025, 05:25:55 PM
Can you access the broken stud with a drill and an EZ out? IIRC, they are 5/16" X 18. Drill a 3/16" hole in the center and see if you can work it out with an EZ out. You can even try a reverse twist drill bit.
Post by: dbzsjones on February 08, 2025, 06:40:08 PM
I think they're a press fit.  I tried a few whacks with a punch but it didn't budge.
Post by: Roger Zimmermann on February 09, 2025, 03:43:53 AM
The torque value is in the shop manual. It's 15 to 20 Ft. Lbs. The stud is a press fit into the flywheel, with a serated shaft. Sometimes I have to replace one because the tread is stripped, but never saw a broken one. Of course, when I'm removing a damaged one, the flywheel is supported at the back, otherwise it's mission impossible. There is maybe a tool to extract such a bolt without removing the transmission from the car.
Post by: dbzsjones on February 11, 2025, 03:15:39 PM
I guess the good news is, I was still bolting up the trans to the engine when it happened so I put the engine back on the stand and the trans back on my dolly.  I did find replacement studs at Fatsco Transmission Parts, part number 8616889.  I also found a local shop that will do the work, and most importantly I found the torque spec table in the transmission section of the shop manual so I don't make that mistake again.
