Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: jamesmundstock on June 17, 2025, 09:17:00 PM
Title: 1955 Eldorado transmission cooler
Post by: jamesmundstock on June 17, 2025, 09:17:00 PM
I know the Harrison cooler mounts to the flange of the transmission pan. I also know one fluid tube connects to the side of the transmission case. Does the other tube connect to a fitting on the side of the transmission pan or is there another port?  I don't have access to crawl under mine to look at the connections so this is why I'm asking. Thanks in advance for the replies.
Title: Re: 1955 Eldorado transmission cooler
Post by: Jeff Rosansky CLC #28373 on June 18, 2025, 09:48:17 AM
Just curious--
I didn't think the 55 had a cooler. Is it an Eldorado thing like the carbs? And/or is the Harrison cooler an aftermarket mod?
Post by: Roger Zimmermann on June 18, 2025, 09:55:24 AM
Indeed, only Eldorado models had a transmission cooler.
Post by: jamesmundstock on June 18, 2025, 11:09:46 AM
1955 Cadillacs with dual Rochester carburetors had the Harrison transmission coolers and the commercial chassis also had the transmission coolers.
