Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: Vinny CLC# 16477 on February 27, 2005, 12:20:59 PM
Title: Need a picture of a 69 DeVille Prop Valve
Post by: Vinny CLC# 16477 on February 27, 2005, 12:20:59 PM
I am converting my 66 front drum set up to a Disc set up.  Can somebody take a picture of the under hood set up of the hold-off(prop valve) and tubing and send it to me?  Also a picture of the master cylinder with the prop valve attached along with the tubing going down to the distibution block on the frame. This would really help.  Thanks in advance!!!
Title: Re: Need a picture of a 69 DeVille Prop Valve
Post by: Lou 19058 on February 27, 2005, 12:34:56 PM
If pics of a 70 will due,I can send them to you. I also have the brake line diagram. I do recall the 69 being somewhat different though.
Post by: Vinny CLC# 16477 on February 27, 2005, 02:29:23 PM
Please do so.  Any help would be appreciated.
Post by: lou on February 27, 2005, 03:14:48 PM
You got mail.
Post by: Alfredo on March 03, 2005, 12:59:38 PM
HI,
Just sent mail to your accounts.
Im doing the same Conversion. Except with a 64 caddy.
Can you guys post the message to the board?
Ive got a prop valve from (I think a 69) and (I think a 70). They are two different beasts. Im not sure which to use.
Im also not sure if I should change to a 70 master cylinder/booster?
What are you doing vinnie?
-al
