Cadillac & LaSalle Club Forums => Technical / Authenticity => Topic started by: Glenn Wilkinson on March 08, 2005, 10:40:34 AM
Title: Fuel system
Post by: Glenn Wilkinson on March 08, 2005, 10:40:34 AM
Im a new member of CLC National as of today, so no CLC # yet. I have 40 LaSalle model 5019. Bought it in Dec. Was fully restored during 95-97. No problems until recently. Fuel line got plugged between tank and fuel pump. Blew the blockage out and things ran great. Apparently the problem has returned. Engine just quits, as if out of gas, but tank is full. Whats best way to trouble shoot and prevent reoccurence? Was restored stock but carb (Carter) is off a 49 Caddy. Thanks!
Glenn Wilkinson
Title: Re: Fuel system
Post by: Bill Hamilton, CLC #16219 on March 08, 2005, 11:23:54 AM
Glenn,
I also have a 1940 LaSalle 5019. I would bet that the problem is in your fuel tank. Sounds like bits of crude are being sucked into the fuel line from the tank and starving the engine for fuel. Perhaps the previous restoration did not include cleaning and sealing the fuel tank. At least this is where I would start. Good Luck.
Bill Hamilton
40 LaSalle 5019
Post by: Bill Ingler CLC 7799 on March 08, 2005, 02:34:59 PM
Glenn- I had the same problem with both my 41 and 47. The 47 tank was full of rust which then pluged up the pick up tube in the tank. The 41 problem was someone coated the inside of the tank with the wrong coating. The newer additives in todays gas caused the coating to loosen and plug the fuel line. I sent both my tanks to Gas Tank Renu in CA. They open the tank, clean and seal it then coat the exterior. They guarantee the tank,cost about $220. As I tour a lot with each car I did not want continuing problems. It sounds like you better pull the tank and look inside then you will have a better idea of the problem. I also install a see through 5/16th glass filter between my tank and aux pump, buy at NAPA. I can see very quick what is coming from the tank
