CAN ANYONE TELL ME IF A HEADLINER FROM A 1956 COUPE WILL FIT MY 1955 COUPE DE VILLE?
The only diference between a coupe and a coupe de ville when it comes to the headliner is that a series 62 coupe has a single interior light, right in the center of the headliner, a true coupe de ville has 2 interior lights, one on each side of the headliner. So, while technically it would fit, you may be left with a big hole in the center for the light. If its a new headliner, I would suspect that they might not cut the hole until it is the car, in which case it would work.
Hope this helps,
Michael
