WTB - 36 75 Series parts
Started by 36caddy, October 28, 2009, 06:11:28 AM
36caddy
Hi Caddy world,
Wanted to Buy (WTB) the following parts for a 1936 75 Series Fleetwood Imperial Sedan;
wheel rim (one only)
hub caps (one or more)
lock assemblies for fender mounted spare wheels (pair)
Side mount cover armature assemblies with with wing nut - the assemblies that hold the covers on (pair)
grille badge
I am in Australia
Cheers
Beege
BJ
Gene Calman
Hi.  When you say armature I presume you are talking about the parallelogram shaped casting and the tee nuts which hold the other part on the upright staff.  I was missing these on my 36 7029 conv sed and made them up  by borrowing the two parts from another collector and haviing them cast up.  the bracket in alum and the nuts in brass.  The bracket can be painted and the nut chromed. I will be in Aus from Feb 19 toMar 10, where are you located?
