connecting rod bolts and cap
Started by mr41cadillac, February 01, 2012, 03:17:52 PM
mr41cadillac
i need connecting rod bolts and caps for 1941 346 engine thanks very much john m sav ga
Make sure to have the rods reconditioned when doing this or the caps/bolts will cause the big end to be out of round.
Just to enlarge on what Dave has said John, hes absolutely right, so I think it would be prudent to get the rod and the cap. I presume your engine has thrown a cap? or what?  and what number rod is it? I know thats not important technically speaking but it would be nice to keep all the numbers in sequence if you could.  I'm in England by the way. Steve
mr41cadillac
what happened is i rounded one bolt head and then tried tocut it off with a dremel tool but couldnt cut completely so then used a bolt extractor and the head broke now im trying to drill out but its of course ruining the cap as well thanks
mr41cadillac
i dont have it out yet but its the back cylinder on passenger side
Thats number 8 then, and its an old problem with the cap nuts, you need to use a 3/8" drive six sided socket on these, too late for you now I guess.
