Tool For Installing Snaps on Convertible Top Well Stainless Trim
Started by Seans 66, July 23, 2012, 02:44:13 PM
Seans 66
This post is about my 66 Cadillac but I have a feeling that many years of convertible Cadillacs likely had the same snaps that my car has.  The outfit that polished all my stainless trim for me removed all the snaps from the convertible top well molding in order to polish it.  Unfortunately, the factory snaps were not really intended to be removed and reinstalled.  I have managed to find the correct snaps (ordered from Danchuk) to put back on the molding but I cannot find the proper tool to do it.  The snaps have an indentation on the shaft that goes into the holes on the trim.  I have a feeling GM used a tool similar to a miniature C clamp that would hold the snap from the top side and then press into the indentation in the shaft to "mushroom" out the shaft so it would hold to the trim.
Does anybody have one of these tools or know where one can be purchased?
Show a picture of your fastener, there are several sorts and different tools for each.
caddychap
If you go to a craft store like AC Moore or Michael's, they will have a tool that you use to install snaps.  I saw such a tool at AC Moore and as I recall, it was quite inexpensive.  Good luck.
Seans 66
Here is a picture of the snaps used on GM cars of the era.  They are different than an average button snap you can routinely find.  The widely available button snaps have a backing plate that is pressed together with the snap.  That would work fine-- if only there was enough room in the trim piece for the backing plate.  That's why I had to got to theses special ones.  Any help is appreciated!
I would think the standard fixing tool would do these types as well.
You could always get a pair of Vice Grips and modify them to act as the installer.
It would require a bit of welding and grinding to both jaws to attach the "Anvil" and Punch" to each jaw.
This way, you will have a controllable pressure to "press and rivet" the fastener into place.
Seans 66
I'll pick up one of the generic snap installers but if that doesn't pan out I'm going to have to go the build it yourself route which I was hoping to avoid.  I don't have any experience with welding or fabrication but my brother in law does.  Guess I'll try hitting him up.  The key willl be to design a device that doesn't deform the snap when you apply pressure.
If only they had left the snaps in place!  You would have thinked they would have told me before they did the work.
Sadness....
