1947 serial number locations
Started by mrb39ms, February 03, 2012, 02:54:44 PM
mrb39ms
Where can I find the chassis serial number on the frame.??
Steve Benson, CLC # 19853
stephen e. benson
Unless Cadillac changed it after the war the numbers are on the top of the frame just behind the left engine mount.
Jeff Hansen
It changed in 1942.  The frame number can be found on top of the right (passenger side) frame rail between the motor mount and the firewall - usually around where the starter and battery box are.
If you can't see it, you may need to sand away any rust or scale in that location.
HTH,
Jeff
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Thanks Jeff, I learn something new every day.
46convertible
Here some picture that i found
Juha
Paul Phillips
Would be curious to see what they did with the 'hidden' additional VIN #'s.  My 41 had a duplicate chassis VIN on the left frame rail under the front passenger area, as below.
Paul
Paul Phillips CLC#27214
1941 60 Special (6019S)
1949 60 Special (6069X)
