need wiper controls plz '76 SDV
Started by Hankk17, November 04, 2013, 07:55:35 PM
Hankk17
Looking for a delay wiper setup (both the interior control module and any relays/hardware needed behind it) to convert a straight non-delay wiper over to delay.
My current wiper control has broken inside and the control lever it just floating around in broken plastic.  it still works, but I don't know for how much longer.
thanks!
Wherever you go... There you are
Hank,
Last time I checked the wiper delay module/relay was included with the "rebuilt" WS washer (from Cardone).  If you are talking about the dash switch a 74-76 full size car "intermittent wiper" (I don't think you could get otherwise in those year's) will fit.
Hankk17
Thanks Greg - yeah I need the "L" wiper switch that goes in the upper left hand corner of the dash.  mine's busted and I want to swap in a delay module anyhow, so this is the perfect time.  So are you saying all I need to do is put the delay module in front of the motor?  There's no different wiper motor, is there?
-Hank K.
joecaristo
Hi,
I have a delay switch and a delay motor from a 78 Eldorado for sale. Should work for your car. Just bolt it in and go. For non delay cars the extra wire needed to the motor is just taped off from the factory. That's the only difference between the 2 set ups. If interested in the parts I can send you pictures. Please email me at joecaristo@verizon.net
Joe
Joe Caristo
Racer81x
Don't know if your still looking, but I have a used working wiper motor and dash switch (the L shaped one)from a 76 SDV $15 each or $25 for both
S. Leist
