1958 Bendix brake problem
Started by Jon S, December 03, 2024, 04:50:16 PM
Jon S
Got the 1958 out of storage today. Started with 3 short attempts after sitting for seven months. Now for the bad news - brake pedal goes almost to the floor upon 1st application; subsequent applications it is fine until the next time you need to stop. I figured low fluid or air in the system. I added a spec of fluid and had my friend help me bleed the Tredle Vac master. No air. I'm thinking vacuum - possibly the one way check valve but the brakes hold fine after one or two pumps. I've never had a problem like this before - if the Master was bad I would expect constant low pedal. Also with engine off it holds firm pedal. Stupidly I played with the adjustable pedal to Master rod to no avail. I put it back to the length it was. Thoughts?
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
Cadillac Jack 82
CLC Member #30850
1934 Harley VD 74ci "Rosie"
1948 Buick 76S "Lillian"
1950 Cadillac CDV "Doris"
1959 Cadillac CDV "Shelley"
Past Cars
1937 LaSalle Coupe
1955 Cadillac CDV
1957 Cadillac Series 62 Coupe
1964 Cadillac SDV
and a bunch of others...
Jon S
Quote from: Cadillac Jack 82 on December 03, 2024, 05:07:00 PMBad check valve?
Maybe. Is there any way of testing it. Vacuum hoses look fine.
Jon
1981 Corvette
2004 Mustang GT
Jon S
Jon
1981 Corvette
2004 Mustang GT
Jon S
Appears to be a leaking right wheel cylinder
Jon
1981 Corvette
2004 Mustang GT
Jon S
Quote from: Jon S on December 03, 2024, 09:01:15 PMAppears to be a leaking right wheel cylinder
All fixed plus Brake hoses we're restricted on the inside like a clogged artery.
Jon
1981 Corvette
2004 Mustang GT
Julien Abrahams
Nice. Sometimes it is something simple. Happy driving 🙂
1951 Buick Eight special
1954 Cadillac series 62
1969 Austin Healey Sprite
1979 Opel Kadett
