1939 series 61 coupe
Started by luv my caddy, November 16, 2014, 04:28:36 PM
luv my caddy
Hello all I am new here.
If all you have is a hole that size its easier to have it repaired.
Quentin Hall
Ironic that a 50c hole costs $50 to fix. . If you are lucky!
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Classic fabrications list them. Yours is the same as La Salle for that year.
Quentin Hall
Take a pic of the affected area. I just had a look at my floor. Very simple to replicate the pattern over a hard edge with a dolly and hammer I would think. Love those 39 front ends. Believe it or not management of the era decided that the 39 front end was the least Cadillac signature front. Personally I think it is the best. Along with 53 and 57. I may be biased.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
57 Biarritz
Quentin Hall
 That looks like an easy fix. I would just plug the holes with a mig. Just do individual dots at the edge and cool with a wet rag. Don't build up the welds too much. One plug at a time. Might take 5 or six plugs to fill the hole. I had a similar cons front pan on my 53 and after an hour of welding and grinding carefully I'd plugged and smoothed all the holes.
This will certainly get you out of trouble and worst case you can always cut out the repaired section and do a more professional repair at a later date.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
57 Biarritz
Sorry, it was C2C fabrications where I saw them. Look under 1937 to 1940 Buick 40 series, they are the same as your picture and $59.95. They are also on ebay under Chev number 151466237054.
