eldorado wheels
Started by Viator Trudeau, September 30, 2016, 10:42:18 PM
Viator Trudeau
  The edge of the wheel where the hub cap teeth grip the very edge of the rim, the rim is curled down a bit to where the teeth of the cap are to are very hard to slip past the turned edge and almost imppossible to remove the cap.
I have eight wheels on two eldos and five spares.  this one only has this deformed rim edge.
Has any ever had a rim like this,  and what to do with it.   Most of my spare wheels are bent and do not balance well on the road.
On some of my wheels the very edge of the rim has gotten a knock
that bent it a bit.  I have taken a heavy hammer and tapped them
back out, so the rim spins pretty smoothly, with good results.  But
I would throw out a rim bent between the center and near the edge.
Have not seen the edge condition you describe.  How about, take a
grinder and remove the bit of offending metal?  Bruce Roe
You could always find an engineering company with a big lathe that can roll the rim back into shape.
Years ago, we had a bodyworks here that had a special rim re-rolling machine, and it got a lot of use.
cadillacmike68
From what you are describing, it seems to be just the edge where the wheel cover teeth grab the ledge.
You can bang this out with a hammer and punch, but expect it to take some time and a lot of hammering. I had one wheel like that, I took a lot of hammering to get it back to where the wheel cover would go on easily. But seeing as these are ElDorado wheesl, you need to do whatever it takes to keep them in service.
"Cadillac" Mike
Viator Trudeau
RE: ELDO wheels, hammering out the " hook" in the edge of the ledge would do the cure for this condition.
A large Lethe would work; with a roller en gauging the under side of the lip, with a back up roller on the top side would do the job.  Set up and some tools from the back of the tool room could be used. I do not know of any one who could do this.    Thanks for the advice.
V.Trudeau
dochawk
