1974 Intake Manifold Wire Loom Bracket Question
Started by hornetball, April 29, 2019, 07:34:27 AM
hornetball
Question for the gurus . . . I thought I had taken enough reference photos, but apparently not.  I've got a mystery wire loom bracket that I bolted next to the #8 runner -- but it's lonely and useless over there.  I'm wondering where it is supposed to go?
The similar piece next to the #7 runner is gainfully employed.
Any ideas?  Here's a shot of the current engine state:
Doesn't the harness/loom with the coil power, trans kickdown, and water temp sensor wires run down that side?
hornetball
No.  You'll notice the "T" in the loom by the PCV valve.  The wires you mentioned T-off from there and go across the manifold to the driver's side.
I've been scouring 1974 engine pictures.  Nothing definitive so far.
