Project - 1968 DeVille Convertible
Started by dwbic, June 15, 2014, 10:15:01 AM
DaddyDeVille
1 Old car (The Green Devil~le) (Lots of gas)
1 New Truck (Not quite lots of gas, but still a lot of gas)
1 New Car (no gas)
1 Newish Bike (Some gas)
1 Old bike (Some more gas)
https://chuckdidit.wordpress.com/
https://www.instagram.com/mightneedoil/
dwbic
Got the hood, front fenders and front bumper installed and aligned.
Don
Don
DaddyDeVille
Quote from: dwbic on April 24, 2018, 09:11:43 AM
Don
Hi Don,  would you mind taking a picture where the fender meets the door and the hood meets that cowel?  The guy that did mine put more shims in it than a door in a late 70s split level house that went through an earthquake.  I'm interested in the gap to see how far out of wack mine is. :)
thx!
Charles
1 New Car (no gas)
dwbic
Charles,
Here are a couple pictures of the gaps and shims.
Driver Side - 1 Shim
Driver Side Gaps
Driver Side Match up of Body Line
Driver Side Gap
Passenger Side - 2 Shims
Passenger Side Gaps
Passenger Side Match up of Body Line
Passenger Side Gap
Let me know if you want more details.
Don
Don
DeVille68
nice work.  8)
Mine has good gaps on top but the driver side door carves a bit too much to the inside on the lower rear corner.
I think mine has 3-5 shims on each side.
Best regards,
Nicolas
dwbic
Windshield was installed a couple weeks ago.  Started convertible top installation - rear window (curtain) is in place.
Don
Don
dwbic
Anyone know how this seal installs?  I don't recall how it came off, and none of the clips seem to line up with anything - what am I missing?
Don
Don
DeVille68
Hi Don,
A few years ago I installed Steele Rubber: 70-1578-64
It looks similar but not identical to the one you have bought from OPGI. But I guess it should be close enough.
There are two tabs on each side, as you can see. There should be holes to screw the end pieces down.
I don't remember if you have to lift the weatherstrip of the door window glass in order to slip the front bow weatherstrip underneath it.
Along the bow there should also be holes. If your top is working you could test fit it with tape and check that the seal is more towards the front of the chrome windshield piece.
I will look for pictures if you continue to have difficulties.
Best regards,
Nicolas
dwbic
An update after a long period of frustration, but beginning to see the light at the end of the tunnel.
I was unable to get the convertible top installed and looking good after months of trial and error.  I finally had to give up and have arranged for an experienced professional installer to do the job in June of this year.
I had the engine running decent and then one day it would not start - the culprit was eventually found to be a faulty distributor.  As a result I decided to upgrade to an HEI ignition.  Installed an MSD system and the engine now starts and runs reliably.
Part of the wiring harness was melted and after spending too much time troubleshooting I decided to rewire the vehicle with a new harness.  That is now complete and things are working well.
I put the car together without a roof so I can at least drive it with the top down for the time being.  I also just received my new tires - I think they look great.  Here are a few pictures as it sits today.
Don
Don
hornetball
Bentley
The car looks great Don. I've enjoyed following your blog over these last couple of years. It's nice to see how the car is finally coming together.
Wes Bentley
CLC # 30183
dwbic
Thanks Bentley.
Completed the exhaust this week and did a little needed tuning on the carburetor.  The weather was nice, so I was able to take my wife out for a ride.  The car is really quiet and the ride is excellent - rides like a Cadillac!
Here is the best photo of the car taken so far.  Lots of little details yet to do, but at least it's driveable.
Don
Don
savemy67
Hello Don,
Really looks nice!  How about another 3/4 photo, but outside in the sun?
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
James Landi
BOLD AND DROP DEAD BEAUTIFUL--- congratulations on your color choices--  Bellissimo James
dwbic
Quote from: savemy67 on April 20, 2019, 09:48:38 AM
Hello Don,
Christopher Winter
Here are a couple shots out in the sun.
Don
Don
spolij
dwbic Try getting the door handle bolts on a 66 deville. >:D
