1976 Cadillac ‘short cut’ heater core replacement 😁
Started by V63, December 27, 2021, 11:17:43 PM
V63
1976 Eldorado needed heater core replaced. Did NOT want to go conventional 16 hour nightmare route. Went With The 90 minute route.
(NOTE: NOT found anywhere in the FSM) 🤦🏻‍♂️
1. Cut and remove firewall sheet metal enough to extract core from engine compartment (create a trap door)
2. Cut and remove rubber sheeting and cellulose insulation to expose heater core.
3. Remove 1 sheet metal screw holding core (between hose connections)
4. Pull core out thru trap door opening.
5. I used 'exploding foam' to line inside of trap door to replace removed insulation.
Whole process about 90 minutes. ☺️
Will update completed job after I image and install 'trap door',
Sure makes it look easy.
Don't know why Cadillac didn't design it that way.
Cadillacdave
I have considered doing the repair the very same way and everyone advises against it. Personally, I think it is a great idea. How much wider were the cuts to the firewall, than the actual size of the heater core, to make the trap door? 1/2 inch bigger than the heater core? Thank you
dennisspeaks
This is great and i will sleep better, I had been praying not to have to do this the conventional way.  It's a no brainer in my book I don't see why everyone advises against it?
CURRENT CLASSIC CARS
1939 Cadillac
1976 Eldorado convertible
1978 Toronado XS
1994 Deville
1989 Fleetwood
1989 Town Car
1982 Mark VI
PAST CARS
1978 Biarritz
1978 Eldorado
1978 Biarritz
1978 Biarritz
1974 Eldorado - RIP
1976 Eldorado Vert
1975 Sedan d'Elegance
1990 Sedan Deville -gave to son
1988 Fleetwood Brougham - gave to daughter
1968 GTO
1965 Olds 442
1975 Caprice Classic Sold
Somehow, I just can't see myself butchering the box to save a few hours of work.
To each their own.
Cadillacdave
I would agree that no one wants a " butchered" job. From the looks of your finished pictures it looks nice and neat and is not " "butchered" at all. If done skillfully in the manner you did it - it looks great! Also, removing a dash to do this job is expensive and it usually never goes back exactly as it came out. There are usually some missing bolts or tabs and then you are stuck with a squeeze or rattle.
We have all seen hack jobs that folks do to cars but this is not it. Obviously, you were careful with the cuts and fit the trap door back where it is barely noticeable. A little sealant and paint and it looks like it was made that way. Great job! Thanks for sharing with us.
James Landi
Back in the "Olden days," on some American cars, the heater core was  easily accessed through a metal panel  on the fire wall.  I do vividly recall that my 56 developed a leak inthe core on passenger side, and peed on a colleague shin. those two cores were in the kick panels on either side of the front seat.
That's a '56, James. Years behind the '76, which is a different world.
jagbuxx #12944
I replaced the heater core on my 75 Fleetwood (now sold) and it wasn't that bad of a job. There are some posts that helped and the FSM of course-except there are 5 bolts to remove, not 4.
My estimate is that it took me about 7-8 hours over 3 days. I would never think of cutting thru the firewall. Sorry, my 2  cents
Frank Burns #12944
61 Coupe Deville Bristol Blue
41 Series 61 Deluxe Coupe 6127D Black
08 STS 3.6 1SC  Thunder Gray
16 GTI Gray
03 T-Bird Black
19 Tiffin Phaeton 40AH
07 Corvette Blue
20 MB S450 White
"Whatever the occasion, there
wrench
On one of my cars, I would do that in a heart beat.
I am definitely a 'better mousetrap' mechanic.
And it's not very hard to build a better mousetrap than GM
I would do the access cover and insulation differently.
1951 Series 62 Sedan
1969 Eldorado
1958 Apache 3/4 ton 4x4
2005 F250
2014 FLHP
2014 SRX
James Landi
"I am definitely a 'better mousetrap' mechanic."
I'm with you Jim...  If I can figure out a suitable "work-around" I'm on it; however, with the more modern computer controlled Cadillacs, the work around usually involves  bungee cords!  James
