1970 Coupe DeVille front seat won’t tilt for rear seat entrance
Started by RCassedy, July 16, 2020, 08:04:54 PM
RCassedy
I’m a recent new owner of a 1970 Coupe DeVille. I can’t find any button or lever to release the top half of the seat to gain access to the rear seat. Any help would be appreciated. Russ
1970 Coupe DeVille
New Edelbrock Performer 600cfm Carb.
Destroyer Gray
22” Wheels
G'day Russ,
If there is no lever to release the seat back, then it could quite possible be that the previous owner replaced the original seat with one from a Sedan.   They will it the mountings, but lack any tilting mechanism.
Cadillac Fleetwood
Your photo shows that the car is equipped with power door locks.  Coupes with power door locks had a solenoid release in each seat back, and a small manual latch at the lower outboard corner of each seat back, to release the seat back manually.
If Bruce's hypothesis turns out to be correct, you can remove the seat shields on each seat back, and remove the locking plate at the lower outboard edge of each seat back, which will allow the seat backs to pivot.  However, there will be no locking feature, and the seat backs will be allowed to pivot at all times. Send me a PM if you need the electric solenoid locks/releases for inside the seat backs.
-Charles Fares
1970 Fleetwood Brougham
1969 DeVille Convertible
1989 Fleetwood
RCassedy
Charles, I removed the outer side shield and didn’t see anything I could remove to release it to tilt. I’m thinking someone replaced the original seat like you guys are have assumed. How do I PM you?
1970 Coupe DeVille
Destroyer Gray
22” Wheels
Cadillac Fleetwood
Quote from: RCassedy on July 18, 2020, 10:33:46 PM
You can send me an e-mail at faresmcmthelix@msn.com; include your telephone number and which hours/days you are available.
Charles Fares
1989 Fleetwood
