1958 transmission oil? Dexron 2 ?
Started by Rdtreur, May 17, 2021, 03:18:59 AM
Rdtreur
I need to fill my transmission with new oil. I got a can of dexron 2 for it but would a suffix A be better?
I did some research online and many people seem to put in dexron 2 as that is way easier to get.
For me the suffix A would take two weeks to get:-(
Many thanks, Ramon
R.D. Treur
Past caddy’s:
‘68 convertible ‘70 Eldorado,  ‘75 sedan, ‘75 Fleetwood
V63
I have been substituting the early dextron versions and am Unaware of negative effects. 🤷🏻‍♂️
It takes 11 qts, ~3 gallons, so one "can" won't cut it.   You have to drain from the front and the back.   Only about 8 come out the back.
The procedure is in the manual.   If it hasn't run in a while, I'd be pulling the pan and inspecting the pickup screen also.   Check for leaks.
The Dexrons are back compatible, so the regular is OK.  They make Dex/Merc now.
Rdtreur
Quote from: fishnjim on May 17, 2021, 09:40:32 AM
I did all the draining , pull the pan and checked the screen... never seen anything this dirty....
This made me remove the brain and opened it. Cleaned it all and now need to refill. I will just go with the dexron :-)
Here are some pics of the dirt:
R.D. Treur
Past caddy’s:
