?Reliable mechanic Houston area for 1973 Eldo 500ci engine work?
Started by Baloo, May 23, 2023, 06:06:35 PM
Baloo
Need several things done on our 73 Eldo 500ci (water pump, valve stem seals, timing chain/gearset, possibly heads re-worked).
It's just getting too hard to do myself anymore, but, darnit, I end up paying stupid money and also end up having to finish the job or correct hired mechanics' work.  Always end up with regrets.
Anyone recommend a mechanic in the Houston (preferably North Houston/Conroe/Magnolia areas).
Thanks.
You might check with the Gulf Coast Region.
Rod Dahlgren #19496
Anyone respond with a good contact? I'm looking for help for friends that have a 1960 Eldorado in Houston
Did You Drive Your Cadillac Today?
