67 coupe de ville
Started by scotzilla, August 02, 2008, 02:47:02 PM
scotzilla
10K-
the car is located in northern california 925-895-8221
scott dees
scott dees
G. Brown
Curious. What kind of body mods did you have to make to dump it that low?  ...and what air bag set up are you using?
G. Brown
scotzilla
zero body mods- Its even got the stock shocks in the rear in the stock location.  6.5 inch bellow bags up front and 7.5 in the back-  I just had some stuff left over from other projects and put it together myself-  3/8ths valves and a 7 gallon tank-  Tons of room in the trunk under the rear parcel tray- good luck
scott dees
