Grill Mounting Question - 1956
Started by Eric Falk, July 22, 2008, 04:40:38 PM
2danreed
Yes, I have a website and you can click to it right below my avatar photo where it has WWW  or type ArtistDanReed.com in your brouser.
I just turned 41 so I have quite a few working years left myself, but this year's GN is in my back yard.
Dan
Dan Reed
Eric Falk
I think it's likely some 55 grills were carried over to 56.  I suppose there could have also been another supplier that provided grills too and installed the tab for some unknown reason.
I won't be at the GN either because I too have to work..... for at least ten more years.
Dan,  Please let us know what you see and anything you learn from others.  Enjoy the GN.  I hope to attend the next one held on the left coast.
Eric
The center bar is different in 1956 compared to 1955; the part number is not the same. I doubt that the bumper and grille assembly is readily interchangeable.
I have 2 '56 cars; they both have that tab, without the clip for a screw.
Otto Skorzeny
Hi Roger,
What are your ID numbers? Mine, which did not have the tab, was pretty late production compared with Jose's.
fward
HUGE VENDOR LIST CLICK HERE
Otto Skorzeny
I'm self employed with my own business. If I'm not there,nobody will be. Then I'll be in trouble with my customers. Oh well.
fward
Quote from: ottoskorzeny on July 26, 2008, 08:22:39 AM
Sedan de Ville: 5662067655, assembled Feb. 29
Biarritz: 5662089578, assembled April 13
Roger
Otto Skorzeny
So far yours is the latest production # with a tab at 89,578.
What are the numbers of some of you other guys without tabs? Mine was one of the last cars produced and has no tab: 150,453.
I bet we'll be able to narrow it down pretty closely as to when they stopped putting the tabs on.
fward
2danreed
Mine is a series 6219 sedan - serial# 5662-147388
Dan Reed
Otto Skorzeny
Well we're narrowing it down somewhat.
Now we know the cutoff for tabs and no tabs is somewhere between 89,578 and 147,388
fward
Eric Falk
As I mentioned previously I have a 6239 with the tab and the VIN is 5662067170.
jaxops
Quote from: Eric Falk on July 22, 2008, 04:40:38 PM
I've rechromed the bumpers and cleaned and installed the grill.  In doing so I noticed a tab on the bumper that appears to be another mounting point for the grill.  Does anyone know if there should be another mounting bracket in this location?
I have the same setup on my limousine.  The response about it being a holdover from 1955 on the new 1956 models seems plausible.  Mine aren't welded in, just bolted through to hold it all together.
1979 Lincoln Continental
