75 Eldorado intermitant wipers
Started by Doug Spingelt, April 17, 2009, 06:54:41 PM
Doug Spingelt
I have intermitant wipers on my 75 eldorado, but the intermitnat part always stops in the middle of the window and not at the bottom.  anyone have a suggestion for adjusting this?  My old honda in college used to do this too, but it meant that the motor was in need of replacement.  Since the motor for the wipers in the caddy is probably more powerful than the entire honda powertrain, I dounbt that is the case.  thanks for your help!  --Doug
Doug Spingelt
Roger H
does it park in the proper position and work fine in all other speeds?
Roger Hundtoft
1936 Fleetwood 8509
Lynnwood Wa
Doug Spingelt
Yes, it parks in the correct place and works great on all speeds. The intermittent works with the annoying exception that it holds or waits while the wiper is in the center of the windshield.
Doug Spingelt
Jim Skelly, CLC #15958
Quote from: Doug on April 22, 2009, 12:06:34 AM
Doug,
I had erratic behavior from the intermittent wipers on my '77 Eldorado.  I replaced the wiper switch and that took care of it.
Wynn Moore
Quote from: Jim Skelly, CLC #15958 on April 22, 2009, 01:18:13 PM
Doug,
Speaking of which, where is the switch for the pump of a 83 Seville that controls the washer fluid?  On the fire wall?
