1940 axle shaft seal
Started by csearider, October 20, 2011, 03:21:52 PM
csearider
Anyone tell me where to get the axel shaft seals for a 1940 LaSalle....or the part # for ordering.
Also is there 1 or 2 per wheel (inner and outer)? Mine were completely worn away.
csearider
That is the seal for the axle shaft backing plate for the brakes and wheel drum
Call:
Olcar Bearing Company
Phone: 910+693-3324
Bearings, seals for axles, clutch, differential, pinion, transmission, wheels.
135 James Creek
Southern Pines, NC
28387
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Classic
Motion Industries      Item Number  01299038
Description 15975 Oil Seal - Inches
MFG. Part Number 15975
Manufacturer SKF SEALING SOLUTIONS (formerly CR)
Price$18.64
Shaft or Inside Diameter Range:  1.594"
Bore or Outside Diameter:  2.758"
Width:  5/16"
Lip Material:  Nitrile Rubber
Construction Description:  Single Lip, Spring Loaded Without Inner Case
Should be available at your local auto parts store as SKF (CR) seal 15975.
Gene Menne
CLC #474
