generator rebuild for 1947
Started by Gary Blakeslee, January 30, 2012, 04:40:20 PM
Gary Blakeslee
I am rebuilding the generator for a 1947 convertible with hydramatic drive.  I have a spare but the pulleys are different in dimension sizes.  One is 3 1/2" the other is 3 1/16" which one is right?
                                                      Gary Blakeslee
Gary Blakeslee
I don't know what the historians would say.  But if you do a lot of slow driving, engine
idling a lot, lights on, running the heater motor, the smaller pulley will help the
generator run faster to keep up.  If its largely at highway speeds/lights off/warm
weather, the larger pulley should work.  Add air cond, better convert to an alternator.
Bruce Roe
Gary Blakeslee
Thanks Bruce,  the small pulley has it's advantages so that's the one I will use.
                                             Gary
Gary Blakeslee
Gary,
The Master Parts List specifies:
1941, 1942, 1946, and 1947      3 1/16" Pulley O.D. of front flange
john washburn
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Bob Schuman
Gary,
The 3-1/2" generator pulley was originally for cars with the 3.77 differential ratio(mostly manual transmission models), and the 3-1/16" pulley was for cars with the 3.36 differential ratio(mostly HydraMatics and optional with manual transmission). The smaller pulley was to compensate for the engine turning slower for a given speed when equipped with the 3.36 differential. The way our cars get driven now, I agree that the smaller pulley is advisable, regardless of the differential gears. If only the larger pulley were available, I would not hesitate to use it, however.
Bob Schuman,CLC#254
Bob Schuman, CLC#254
2023 XT5
