Need 1938 LaSalle Drivers Side Running Board
Started by Dimaggio, January 19, 2013, 07:02:05 PM
Dimaggio
Looking to buy a drivers side running board for my 1938 LaSalle.  My drivers Side running board appears to have been damaged in a collision many centuries ago and repaired.  I need a replacement where the structure is in good condition.  I am not worried about the rubber.
Kevin Ackerman
1940 lasalle man
Hi Kevin
     I have a set of runnings board from a 1940 cadillac lasalle. If the measurements are the same I may have what you are looking for,you can reach me at(570)876-5687 with the measurements. Looking to hear from you. You may also contact the technical section of the forum to find out if the running boards will match  Sincerely M McDonnell
Dimaggio
Thank you, I will look into it to see if they are the same measurements and will get back to you.
Kevin Ackerman
