Under dash FM receiver for AM radio.
Started by Gene McCormick, April 25, 2013, 01:14:58 AM
Gene McCormick
These little under dash FM receivers were common on ebay but since ebay has so much auto spam they hard to find even
if listed. I know the FM units work only well on Cadillacs that are transistor AM. Its a lot simpler to have under dash FM unit
and easier to install then a used am/fm car radio. I would like to buy from a member or help finding one on ebay. Gene
52Cadillac
Hi Gene,
I also am searching for a similar item. I was gonna send radio out to add fm, but wouldn't use it a lot. So I'm thinking a plug in device. I've a cigarette lighter, and one of these may work for me. Easy to throw in glove box when not in use. Don't know about how to hook up the sound or speakers yet. I'm still researching. Your right these aren't easy to find on ebay.
http://www.ebay.com/sch/eBay-Motors-/6000/i.html?_vxp=mtr&_nkw=car+fm+transmitter&LH_PrefLoc=1
Regards, Mike
SemperFiFund.org
Jay Friedman
#2
I found several for sale on ebay using the search words "fm converter".
If none of those work out for you, I have a used one I'll sell for $30.  jaysfriedman@yahoo.com
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
52Cadillac
Jay, is that the kind that hooks into the antenna slot? Does it mount hidden? Speaker hookup?
Thanks, Mike
SemperFiFund.org
The old FM converters installed with a connection to power and with an inline antenna adapter.
It would convert the signal to FM and the AM radio needs to be tuned to either the top or the bottom of the dial, I forget which. The sound comes from the existing radio and speakers.
But, you control the stations with the converter so typically they are mounted and visible so that you can change stations which might not be what you want.
Brian
Jay Friedman
In general, the way it works is that the converter is sending an FM signal to the AM radio.
As 76Eldo said, they have 3 connections:
1. A power wire which should be connected to the ignition switch;
2. A female anntenna jack, into which you plug the cable from the car's antenna which previously had been plugged into your AM radio;
3. A male antenna cable coming from the converter which you plug into the female anntenna jack on your AM radio.
It is mounted under the dashboard and is visible.  Use a metal mounting brackets of some kind, which you'll have to fabricate yourself (unless you buy a new one with mounting brackets included), as it grounds itself through the bracket.
The converter has a button or switch to switch it from AM to FM play.  To play FM, you set the AM radio to usually 1400 (on some models to some other station) and press the button to the FM position and the system will play an FM station.  The sound comes from the AM radio's speakers.  The converter has a station selecting button and an FM stations dial.  Sound volume is controlled through the AM radio's volume control.  To switch back to AM you press the AM/FM button on the converter.
Decatur, Georgia
52Cadillac
SemperFiFund.org
Renato
I have an AM transmitter to my 57. It works from cigarette lighter and mp3 player. I can use my original radio with the original speakers.
R. Bognar
52Cadillac
Renato, I've seen those on eBay as well. Just pull out and throw in glovebox. Inexpensive also. Did you mean FM?
SemperFiFund.org
