1940 Lasalle horn location, HELP!!!
Started by gary griffin, May 01, 2014, 11:19:25 AM
gary griffin
When I purchased my 1940 series 50  LaSalle my horn relay wires were cut and the horns were in the trunk.... I suspect that this is the wrong location for the horns!. Does anybody have a picture of them mounted in the proper location to post please?
Getting ready to sort out my electrical oddities and install a new wiring harness from Rhode Island.
There seems to be an odor that I remember from electrical issues so I know I have a Gremlin or two hiding somewhere in my car. The spot light wires have been cut also.  Someone took the easy way out instead of taking time to do it right.
Gary Griffin
gary griffin
I am hoping someone has a photo to post or e-mail to me so I can get it right.
Gary Griffin
I cant answer for La Salle Gary but my 1040 Cadillac had the horns pointing downwards in front the radiator behind the grill.
gsnood
  I have a 40  5019, the horns are mounted on brackets which mount to cross-member just ahead of hinges rear of hood.  Center of hood out to center of brackets is nine and a half inches. Cant vouch for authenticity on this but it looks stock. C.B.Michno  #28530
gary griffin
C. B Michno,
  Thanks, I looked into the dark and behold a bracket with screw holes on each side is residing on the underside of my hood, a perfect match to the holes in the little brackets on the horns. I have not tested the horns yet but they are freshly painted and I suspect someone has worked them over.  They are the short version instead of the long horns on my Cadillac but when I looked them over they appeared different. They have spiraling air chambers of different lengths which I imagine gives them different tones.  I will be interested in hearing them later.
Steve, My 1942 Cadillac has the horns between the radiator and the grille also.
It looks like a short run for a wire from the horn relay to the left hand horn then a wire across to the other one.  Now to  get an installation that does not get damaged by the hood when it is opening and closing.
Gary Griffin
