79' Seville Cornering Lamps Not Working...
Started by tamisterling, August 22, 2016, 12:48:30 PM
tamisterling
Cornering lamps still not working after replacing with all new bulbs; fuse checked and OK.  Any ideas??
Eric DeVirgilis CLC# 8621
Do you have your parking lamps or headlights on? The cornering lights will not operate otherwise.
Walter Youshock
Check the wiring at the bottom of the steering column.  And eric is correct --they only work with the head or parking lamps on.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
tamisterling
Thank you Walter Youshock & Eric DeVirgilis, I will check both the wiring and make sure the lamps are on!
