tie rod ends water pump for 37 series 75
Started by boothandco, June 20, 2017, 12:04:29 AM
boothandco
Looking for x correct the rod ends for a37 75, inner and outer.  Bought some last year and they were far too big.  Also Pittman arm, and a water pump.  The pump will actually go in a 47 motor.  Contact Chad @ Boothandco@sisna.com
Chad Booth
1937 Series 75
1999 Fleetwood Limited
1976 GMC Motorhome
Previous:
1989 Sixty Special
Reformed Lincoln 4 door convertible owner.
boothandco@sisna.com
Water pumps are on eBay all the time Chad.   Your rod ends should be the same as all the bigger series which is a bit confusing because the small are only for the small series unless someone's changed your rod in the past?
mribbich
I have tie rod ends for you 1937 series 75 car. 1-262-392-2989 or mribbich@wi.rr.com
Marv.
boothandco
Thanks Steve, could the whole tie rod set be the wrong ones?  Does anybody know the diameter of the proper tie rod end for the 75?
Chad Booth
1937 Series 75
1976 GMC Motorhome
Previous:
1989 Sixty Special
boothandco
Steve, I see lots for pumps on ebay, but I also will need a pulley for the unit.  It looks as if the pulleys between the 37 and 46 must have changed.  Of course, as it is going into the 37, I guess i need the 37 pulley.  Any thoughts?
Chad Booth
1937 Series 75
1976 GMC Motorhome
Previous:
1989 Sixty Special
The MPB actually shows a different pulley for the 38 as well as 1940 on. I'm nor completely sure what these differences are between 37 and 38 but I just compared my 37 pulley with a 41 and the 41 is very slightly larger.  The difference is negligible but I suppose it would change the belt size slightly?
They all interchange though.
