70 Deville front brake rebuild bleeding question
Started by Bill Kaufman CLC# 15225, October 20, 2017, 02:02:17 PM
This one has me stumped..  I have installed new calipers,shoes and hoses on the front of my 70 De ville. I am in the process of bleeding the brakes as I have done many times using a vacuum pump. But...  the pump pulls and holds a vacuum after I have opened the bleed screw with NO fluid. This is happening at both front wheels. I have removed the brake lines at the metering valve and used my air compressor to blow the lines to the metering valve from the master cylinder and to the two front wheels from the metering valve. The service manual mentions to use a tool to retain the metering valve. ? does the retainer hold the pin up or down ? what do y'all think may be going on here ?
Bill
CLC # 15225
If you ain't Wrenching ...  You ain't Livin.  So get out there and Live a little..  !!
Current Labors of LOVE;
1948 series 62 Club Coupe / 346 L head / Rendon Blue
1954 series 62 Sport Coupe / 331 V8 / Aztec Red
1970 Deville Rag Top / 472 V8 / Nottingham Green
Previous Caddies ;
1969 Fleetwood Eldorado / 472 V8 / Wisteria
1974 Sedan DeVille
1993 SLS / White Diamond
2006 CTS / White Diamond
Previous Caddies ;
1974 Sedan DeVille
