1940 lasalle 12 v conversion condensor
Started by amolnayak, March 13, 2018, 09:06:13 AM
amolnayak
Gentlemen
What condensor should i use for a 12 v 1940 lasalle 52 conversion? I assume the 6v condensor will not work!
Amol
1940 Lasalle 5227C
1956 Mercedes Benz 180D
1956 Fiat 1100 103E
1961 Rover P5 (now sold)
1992 Eunos Roadster V series special
You didn't say which condenser.  In general the voltage rating of
early auto caps is not tied to the battery voltage or polarity, a
6V pos ground works for 12 neg ground. It might have a rating
of 400 volts.
This is not true of newer electronic type chemical caps.  Bruce Roe
I presume you're talking about the condenser in with the points?  I have never had to change one for a conversion and I have only twice seen them rated for a voltage.
Yours will probably work. We always use 60s GM models like below.
https://www.ebay.co.uk/itm/BEDFORD-CA-VAN-65-69-BEDFORD-CD-CF-ED-EF-JO-MF-NEW-IGNITION-CONDENSER-33760/141204192535?epid=1925137914&hash=item20e06cfd17:g:DVQAAOSwxH1UExky
amolnayak
Quote from: Steve Passmore on March 13, 2018, 06:44:50 PM
Thanks Steve on your advice I started the car with the existing 6v condenser and left it in for 1 hr and she works perfectly. Thanks again for your advice....Amol
1940 Lasalle 5227C
1956 Fiat 1100 103E
Amol,
Last year, 2017, in the Self Starter I did a fairly comprehension article on condensers for Cadillac. You might want to review it. Should answer your question on the condenser.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
