1941-62 Distributor
Started by bernie schweiger, March 19, 2018, 08:09:36 PM
bernie schweiger
I need one of the balls that ride inside a distributer and allow the vacuum advance to work. There are three balls which look like a ball out of a ball bearing. The ball measures 0.218 inch or 7/32 inch. WW Grainger will sell them in a lot of 100. Does anyone have one?
Bernie
Many companies here sell much smaller amounts like the link below. just a few pounds for 10. Have you searched all your bearing suppliers online?  Have you tried in a bicycle shop?
https://simplybearings.co.uk/shop/product_info.php?products_id=38914&vat_inc=true&gclid=CjwKCAjw4sLVBRAlEiwASblR-6lUcwdAFc_FUbocMwgWPl5gqptYZp9EVnCLTpucSK4UTBf9VQVh-xoCJdMQAvD_BwE
bernie schweiger
Thanks Steve, I will try a local bicycle shop .
Bernie
Bernie,
I replace the distributor plate with the newer ones that use ball bearing in the center of the plate. Even Delco put out a newer version. I might have a nice Delco one if you are interested.
Do a search on e-bay on distributor plates and see if one pops up. Dyna-Flyte is the one I buy. They are a bit pricey.
If that don't work I probably have some lying around since I rarely thow stuff away.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Bill Ingler #7799
What you want is a Dyna-Flyte 880-C.  There are now several 880-D on ebay but they are dual point.  Bill
